Trafic 140dci
				Ok so my 182 i got cheap as the clutch was slipping, anyway changed the clutch, put it all back together, and i noticed that when putting the cable on gearbox that i had to pull the lever in alot to get it in, so once the cable was on it held the clutch slightly engaged (if that makes sense.) So i'm thinking that my cable is to short so is leaving the clutch slightly engaged when the pedal is up.
Has this happened before? Could anything be causing this?
