Clutch Centre plate - Help?
Car  Tungy
Took the gearbox off the engine and stripped the clutch last night. Doesn't look too bad, but I wondered if anyone knew the specified thickness of a new centre plate, and the minimal thickness on a worn one? As I have nothing to compare against and no dimensions in the Haynes manual I'm unsure whether to buy a new clutch kit or not. Cheers
New are about 6~7mm I think.
Just replace it personally its not much and you'll know how annoying it is to change if it breaks after you put it back. Just use Renault original though there the best.
as its all apart, for the sake of £90 odd put a new one in there, no point pissing about!
do you have all the correct tourqe figures??
90 quid? made of gold is it?
16V clutch LUK or SACHS 50 qudi from the factor, Valeo (which is oe) is abotu 60 for the heavy duty effort from euro.
well i've just been out with the Sweeden national reserve football team (female) ;)
lets just say, there's no mingers in sweeden! ;)
A swedish girl has just started work at my place, she is minging i guess the swedish goverment deported her
