				Many thanks for the reply
Yes all bolts were equally tight, or definitely not noticeably loose when I took the clutch out.
These were the top 2, if that is any relevamce.
Generally only me who drives the car, just on track now. Historically I've been pretty light on clutches, the car is 132,000miles and came with all the bills which don't include a new cluch, and we only replaced the original with this one as the geabox was out for the new diff.
But a couple of others have driven the car on trackdays this year, so if abuse could really cause this I'll have a look at the in car videos!
Can you adjust or limit the pedal travel so you can't overforce the release bearing?
Also I can't really visualise why this would make it impossible to change gear at speed, but okay from cold at low loads???
I'd love to pinpoint a cause to try and prevent it happening again, particularly as it's such a job to get at the thing, but looks like I might end up having to put it down to product fault.
Cheers, Andy
Thats a LUK clutch, be intrested to know if the pedel feels any different to the genuine one (VALEO) once you have it fitted.
The genuine Valeo should arrive tomorrow, so with any luck I should be able to give it a test sometime at the weekend.
The LUK clutch is way cheaper, so I'm hoping that has something to do with the failure.
When it was first fitted the feel of the biting point almost disappeared, but I'm putting that down to the lightweight flywheel that was fitted at the same time.
It will be interesting to see if some of that feel comes back though.
@Touring_Rob the fact that the clutch plates don't necessarily keep a flat rotation could well explain the problem, particularly if you add in everything heating up.
Could explain why gearchange is fine cold and low revs, then suddenly blocks after some use. Leave idling in neutral for a time to cool down and everything works again. Let's hope so anyway. Many thanks for your help, and glad you didn't get thrown off the bike!
It’s not one I’ve ever seen mate and I’ve seen valeo clutches doing destructive things. The genuine Renault valeo doesn’t though - go figure.Were the bolts tight?
The only thing I can think of is that either the bolts were loose and it fatigued that section of metal or someone has been absolutely booting the clutch pedal to the floor and fatigued it that way 😂
Either way it's the first time I've seen that happen! @NorthloopCup you ever seen this?
You need to reset your clutch ratchet. Take the cable off at the box and pull it all the way out. That lifts the clutch pedal in the car and should reset the ratchet.Thanks Andy, yes glad I didn't come off either! Best of luck and hope all goes to plan for you.
My newly fitted Valeo has a very definite biting point feel although I do have a standard flywheel.
Rob,
I've seen plenty of the new style cheap s**t Valeos buzzsaw their way out of the bellhousing like "PEEKABOO IM HEREEEEE"😂It’s not one I’ve ever seen mate and I’ve seen valeo clutches doing destructive things. The genuine Renault valeo doesn’t though - go figure.
EFA 😂Your just full of the truth for me today Kyle
My GSF valeo clutch has been fine. HTH
He helped me fit my clutch! 😂I personally, after a sleep have just decided that its only the clutches and cooksports fitted by Yorkshire Pudding that fail - mine will be fine and if they fail I won't be telling him.
No mention of threadlock in the renault maual just saysAre you supposed to use threadlock?
Gradually screw in the bolts in a star formation, then tighten the cover mounting bolts to the specified torque. 20 nm
Think we all are, good luck with the strip down.bit intrigued as to what I might find.
What release bearing did you use? And did you put it onto the fork properly?
Sounds stupid but I find its always something trivial that messes s**t up
Did you fit the clutch plate the correct way round? Sometimes they have a flywheel side/pressure plate side - just an off the top of my head thought mate.
