Clutch - which one? Clio 182 2005
  Clio 182 cup
Hi
looking for a new clucth on our Clio 182 2005. we only use it for racing so would like to look into something a bit better.
Is there a noticeable difference between that and a standard
any suggestions
links?
cheers
  Clio 182 cup
Excellent. need one in the new year so i will be in contact.
what about a radiator?? any suggestions or ideas? its just to get extra cooling to the car. benificial?
JP83
South Central-Oxfordshire
Check out some of the project threads on here. I know a few of the proper racers have changed rads. I think @Tony Hunter used a Polo rad? He'll correct me I'm sure.
A couple of folks have used the Direnza type ones too.
  182cup & 172 racecar
Valeo is fine, unless running 220 plus and more torque.
Had a polo rad, which was fine, but after the flywheel came off, and damaged everything under the bonnet. I've replaced it with a Fabia one. It's a little longer, but still only £40 odd, light, and no problems.
  Clio 182 cup
Tony
excellent stuff. a couple of peole have said that a Valeo is fine as i only running the engine as standard. also suggested the current Rad is fine as again the engine is standard.
On a different note. if you to have a second set of wheels with good rain tyres with in the 1a &1B tyre regs which would you say are a good choice?
Which wet tyres do I use?
R1r's. Excellent in the wet, I wouldn't use anything else.
Others may say different, but I found them to be the best.
  Clio 172 (CUP)
Tony, have you got a link to that fabia radiator you could share, thanks?
