Code 257 throttle position sensor.
  Renault Clio Sport
HI everyone,
I HAVE JUST CHANGED THE CAMBELT ON MY CLIO SPORT AND I NOW HAVE A PROBLEM WITH THE THROTTLE POSITION SENSOR. MY DIAGNOSTIC TOOL READS A FAULT CODE 257 throttle position sensor. IT IDLES A LITTLE TOO FAST AND I HAVE NO POWER AT THE ACCELERATOR PEDAL. As I did a CAMBELT change I have had many wires disconnected, I also replaced my auxiliary drive belt, water pump, inlet manifold gasket, air filter and spark plugs. Does anyone know what I have done wrong whilst completing this work that would cause this to happen? And what can I do to fix it??
Hope someone can help?
Kenny.
  Renault Clio Sport
Haha I Thought you were taking the michael, just went into the garage to check the sensor was plugged in, I hadn't pushed it on far enough, just heard it click into position! Revs perfectly now and Ive completed the job. Thanks a lot for your help, was only something simple but it was driving me mad! Just gotta put all the plastic crap back on the car now! let's see what else I ca break! :D
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
School boy error... I've done it before myself (I've also forgetten to reconnect the clutch cable before to).
  DON'T SEND ME PM'S!!
I on the other hand have never made the exact same mistake so knew what the solution was straight away........obviously
