Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
I fitted an omex on my friends fiesta st. On that there was a 3 pin plug, negatives on either side and positive on the middle. Is it a 3 pin plug on a clio too? Check it with a multi-meter. Ryanph1rs
Believe the positive is the white wire and the 2 negatives are below that but im getting nothing im told its a wasted spark set up and a might have to wire to 1 negative and set it in 2 cylinder mode .... ive just emailed omex
I cant uploads a photo as im in work its set as the white is the positive and thr other 2 wires beige and salmon pink are the earths ... ive tried a combination of wiring and cant seem to get it active... the box its self is working and all the functions work as should its gotta be something to do with these coil wires
Sorted this now earths are salmon pink and beige wires the lore limiter has to be put into two cylinder mode as it's a wasted spark ignition emailed omex and they also helped there very good and can't fault them atall
