Coilover Opinions
Ring damper tech they are only up the road from us. They will make you a set of springs for between 50-100 an axel.
Ktec back in the day did say they planned to release differant spring options.
Yeah just had a quick look at their webpage,
Still says they are in Brampton:S
Might have a trip up next Monday when im off.
Is these the guys who made GAZ then and "Supply" KTEC
Need some recommendations for a set of coilovers.
At the minute ive got KTEC coilovers on but would prefer something a bit firmer when cornering.
Dont want to be looking at over 1k price wise and would be really helpful if you could explain the difference between all the FK kits.
Looking on Kamracing btw.
http://www.kamracing.co.uk/index.php/renault/renault-clio-mk2/suspension/coilover-kits.html
The Highsport coilovers have fixed damping and galvanised steel struts
The Konigsport coilover kit has koni damper inserts with adjustable damping and galvanised steel struts
The Silverline coilovers are the same as the Highsport but have stainless steel struts
The Silverline-X kit is the same as the Konigsport kit but has stainless steel struts
