Coilover upgrades,what are they really like?
Car  MK2 FRS/Mini Type R
Hi folks,
Ive just read quite a few posts about suspension mods and am really fancying getting me some nice coilovers as seen on a previous thread..
KTR/FK COILOVER SUSPENSION KITS from K-tec.
Ive had a few pretty bad experience with lowered cars, ie bumpy ride/inside tyre wear and a pain in the ass to fit. I was hoping some of you guys could give me some indication to what/if any bad points there are in purchasing a set of these??..
Chris
no bad points. Ride quality problems are overcome with a good damper setup and helper springs. Inside tyre wear is caused by incorrent camber settings, with the fk's you can have it adjusted (they have an elongated bolt hole to allow adjustment)
You can get separate camber bolts I think?
I'll be going williams set up when I can afford it rather than coilovers - not the greatest roads round here so would actually like to keep my fillings in my teeth... lol
fk's wont be harsh, much like H&R's, the soft helper springs make sure of that.
You can get camber bolts btw, but you dont need them with the coilovers.
Coilovers arent always hard...depends on the valving; i.e. go to a low end manufacturer and you will get poor quality internal components and incorrect valving specification therefore resulting in a harsh ride.
John2Modified said:
a fair bit cheaper than KTec!
give us a call, we can answer any questions :)
And we are a Mail order company based in Surrey, www.2modified.com
LOL at the one upmanship! Awaits David to come on a b**ch slap you!
Coils are....hummm...hard, and kind of unnecessary for the road. If most the coilover boys inc myself are bein honest there more for looks than performance. Although u have both if you need it..
Eibac pro dampers and 30-40mm springs are more than sufficient for road comfort and track days...Been there, tested both, and i know which are beta! lol....
Well I was thinking of changing the front struts cos when I corner quite hard I get a knocking from the suspension and thought I may as well upgrade to coilovers.... but knowing my clio there would still be a knocking from the suspension but id have a hard ride too.....
Incidently, has anyone had a similar prob with the suspension??..
If so can anyone offer me any advice??
Chris
depends on usage, mine are firm but not harsh but can be adjusted, as for being necessary it depends on how you like your ride eh, im running KW's (v2), handling is very good.
