Coilovers for a mk2 ph1 1.2 8v 5 door bolt gap?
Car  clio 182 cup
Hey guys im fairly new to this, had my car a little while now and seeing all of the other cars i thought why not give it a go. Im planing on getting vmax coilovers from k-tec the only problem is that i dont know if my car has the 52 or the 58mm bolt spacing on the front strut?
Any help would be great :D
Welcome :)
Im pretty sure you turn your car to full lock one way then measure the distance between the centre of each of the 2 bolts that hold the " suspension unit " itself to the hub. so measure the distance between the centre of the top nut, to the centre of the bottom. Hope this helps somewhat.
this has been covered and covered and covered!
it could be either! just take a wheel off and measure it!!
welcome to CS btw!
