Cold Air Feed - Where
  Skoda Fabia vRS
i had my car up on the ramps last night lookin at the alternator ready for when my new one arrives
anywayz, i decided to have a look at the cold air feed
i found that it goes into some kind of box near the wheel arch/front bumper
but the thing is, its above the fog light but below the headlight, meaning, its entirely bumper in front of it
also meaning my induction kit is basically getting NO proper cold air feed, there is also a hole in the original feed pipe which looks like its meant to be there
where else could i put my feed pipe as the OE place is just sh*te basically
  Cupra K1 & Clio 200
I dont know if this helps, but i just fitted a K&N induction kit to my Clio yesterday. Anyway, i got a cold air feed pipe with the kit and placed one end about 6 inches from the induction cone, and the other end ran done the front of the engine. Below the heap lamp and to the side of the filter.
Depending on what Clio you have, at the bottom there are some vents and i just stuck mine right between 2 of them. This really does give you the maximum cold air possible. You can see my pipe if you bend over a bit (cut the jokes) and look directly at the bumper, but it really does help a lot because there are no obstructions.
Gengar
  Skoda Fabia vRS
i do have a gap under my headlight
its only about 1-2cm though
would it be possible to form some kind of thing to fit in there and channel the air into a pipe
maybe use fibreglass somehow, anyone any experience with moulding stuff like this ?
