Cold Air Funnel
  178hp 172 Cup
has anyone done one through the fog lamp hole??
i hav run a CAF to the nearside fog lamp hole ( Lamp removed ) but it looks s**t and i was thinkin about using a Cold Air Funnel to tidy things up a little!!
has anyone done this and if so what size funnel did they use?? any pics plse??
thanx peeps
theres loads of pics if you do a search for cold air feeds or something in sure youl get an idea
A lot of people cut a small portion of the front grill and the liner out so to get a feed in about 70-80mm is ideal any bigger and its a bit of a squeeze
  178hp 172 Cup
i dont really wanna cut into the front grill!! i worse comes too it i will jus put black mesh over the fog lamp hole
  Titanium 182 & 306 Diesel
Thats were mine is - In the grill
You can take the actual lamp out and just leave the black surround intact and use that as a feed but youl have to change it for the MOT or remove the other one too, Personaly i think CAFs are a waste of time anyway
You wont get any 'ram air' effect I have just removed the feed to the acoustic valve on mine and changed the other one with a bigger one and stuck a green cotton in it
  178hp 172 Cup
my acoustic valve has been removed and i hav run a new CAF from the ITG Panel filter to the fog hole!!! i jus wanted to tidy things up a little!!
  80MPG BEEZA
i have caf on both sides with the same above end piece someone may have a pic i dont have any at hand
Sheila’s’ Wheels’
  Whichever has fuel
Cold air feeds are pointless unless you have a Viper typre filter.
My track car just has the feed poking out the hole where the fog used to be. (but i don't care what it looks like! lol)
Mine...
Someone with some time and patience....
