colourcoding
Car  EK4, 632 on black, Mk2Ph3
im going to do this myself for the very first time...
i just need to know what wet and dry combo to use...
P180 and P320 will be enough to smoothly rub down the black strips?
thanks...
vin
I spent hours drysanding the sidestrips until they were smooth and i mean really, really smooth.
I used 240/400/800 wet & dry to do it.
does it have to be completely smooth, ive spent 3 hours sanding the back strips and my back is aching!
im sure if u primer it when its not completely smooth and then try to wet and dry it down, it should give the same effect?
Well I spent an hour each on the side strips and about 2-3 hours for the door strips.
After you do a couple of layers of primer and then wetsand it should be good.
