common problem again
  • Thread starter Thread starter v11ous
  • Start date Start date
V
v11ous
hi i know this is a common problem just wonderd if any 1 can help me there is water leeking under my splliter by the bumper and i have noticed my headlamp washers dont work and the passagers side leaks by itself it looks like its crying
what is the problem and how much will it cos t me to fix cheers:mad:
You'll need to either repair the headlamp washers or just buy a new set (about £10 each) the problem is common as you say, and they'll only leak again sooner or later. Sounds like they've cracked or blocked if they don't work atall. They only work with dipped beam lights on just so you know aswell.
See this thread for more info
knackered headlight washer, last time I got one it was £7 odd from dealers. If they fit it expect about an hour and half labour ontop of that. You can DIY easily though.
