Compbrake top mounts.
  clio 172 phase 2
Basically took my coilovers out today to check the top mounts basically the top mount had no resistance it was very sloppy . Also the bearing was dry and had little flat spots all around. I just want to know should the top mount be pretty stiff .
Umm like when you have a broken track rod end it wiggles around with no resistance . But when you replace it new one is quite stiff ? Sorry for the rubbish example.
