Cool pack and ignition lead order check
Joe#
The coilpack is labelled up, right where the bolt holes are there is a little number. HT lead number 4 is the shortest lead iirc, if not number 1. So that goes to the far left hand side spark plug.
  clio 172
So the shortest lead connects up to 4 on the coil pack and plugs into 1st spark plug hole ?
so number 3 on coil then go to the 2nd hole ?
Number 2 on coil pack go to the 3rd spark plug hole ?
and number 1 on coil should be longest lead and go to the furthest right towards passenger side ?
is that correct ?
  clio 172
I've got my leads as per above .
ive now got the ignition fault light on dash .
Not sure if this is a coincidence or I have got a fault which is preventing it from starting.
connected up my spare coil pack also and the same .
its a square with a zig zag
