Coolant Capacity
Car  Black 182 FF
Anyone know the capacity of the 182 FF coolant system?
I've got a 1 litre bottle of Fuchs Eskimo lying around and as I've no idea when mine was last changed I was wondering how much more I'd have to add to it if I do a change soon.
total capacity is apparently 6.6L, but you'll not get that much out of it unless you flush the block and the heater matrix
not sure; i've used the pre-mixed Renault Type D coolant (which is green)
you can apparently create coagulation problems if you mix different types of coolant. i'd flush the entire system thoroughly if i were using a different coolant type, and follow the concentration recommendation that comes with it (usually 50:50)
