Focus TDCi
Before anyone says anything I realise all the engines have different cooling setups, but I'm hoping someone will have a clue what I'm on about!
I've just finished rebuilding everything after replacing the headgasket on my engine and as I'm filling up the coolant it's leaking out from the end of a pipe that passes in front of the engine behind the exhaust manifold and finishes somewhere behind the alternator on the front left side of the bay (looking towards the car).
The pipe itself feels solid rather than rubber. Tracing it back, a rubber pipe leaves the expansion tank at the back right of the bay and comes toward the radiator where it splits - one going to the radiator and the other connecting to this metal pipe.
Am I right in thinking it is going to the water pump? If so how does the pipe connect to the pump - is it perhaps the case that I've failed to tighten up a bolt that's caused the gap between the two? I don't recall ever touching this pipe at all tbh, or even the water pump.
Reaaallly can't be mithered stripping everything down again, so I'm hoping I can access it behind the cambelt cover while leaving the belts/alternator/PAS pump/exhaust manifold on?
Thanks for any help,
Ian
Ian
