Cornish 172 Flamer
  clio 172 2002
partly sorted now :) was a bent stub axle which i got from a local breaker for £30, just needs abs rings and a shim spacer for the left side and should be back to normal, Also got the 90degree bend today for the 'The fatty's' air intake setup and it sounds f**king AWESOME! and i think pulls alot better will try it out on the a30 when i get the abs and shim sorted :)
McGherkin
McPension
Lucky you haven't wrecked too much then :) all the same I'd still get the geo checked before doing your test just to make sure it's completely solved the problem.
Can't wait to fit mine!
  clio 172 2002
getting tracking checked ina bit will ask them to have a poke and look around too and check the wheels hit to see if its still straight to see if i can out it back on cause the spare is low on tred
  clio 172 2002
tracking was done and was out about a inch on the front left, just about to order the abs rings and the spacer i need and then back to normal minus the passeneger seat took it out to sow up but might get some buckets but not for a while, now starting on tidying things up, started with the wheels :smile: just a rough part refurb as these will be my winter tyres.... But messed up first wheel mixing brands of paint, used a cheao brand gloss black then used simonz clear lacquer and it didnt like each other and left some bubbley marks :( just rough winter wheels to no worries :p
