Correct way to change glow plugs
Car  Arctic 182
Hi guys wondering if you can help, i think i need new glow plugs (the electrical fault light on the dash has come on) so im asking what the correct process is for changing the glow plugs, this is my first diesel so im not sure whats what, where would you recommend buying a set from and how much should i pay? any advice would be appreciated, thanks ricky.
Go to Renault see what price they are theyre not much.
Vauxhall also keep them in stock as there used in there vans.
Easy to change just unplug the wire on then and undo them with a spanner do them back up to about 15NM I think.
Thanks eddie, im assuming the glow plugs need changing as the electrical light has come on (one below petrol light) so this is the first step, i will ask the renault dealer after work thanks!
Check the plugs they should be 0.6 ohms resistance if not chnage them.
Renault you need to get the computer plugged in see what the exact fault is.
