corsa alloys on a clio???
  clio 5door sport rep
hi guys quick question
will alloys that came off a corsa fit a clio? from what i gather the 4x100 pcd is the same
but the centre bore on the corsa is 56.1 or something but a clio is 60.1? will they fit or not or can i use spigot rings? also i believe the offset is slightly out from a clio what impact will that have... thanks
I think you've pretty much hit the nail on the head, PCD is the same but bore is smaller on the vaux... As far as I am aware this means spigot rings won't solve the problem as they can only make the bore smaller. Solution would be to machine out the inside of the wheel to increase the bore. Possible, but probably not worth the hassle.
RE Offset, no idea what the vauxhall is, but if it is stupidly low, the alloys will sit too far out into the arches
