Corsa B Springs 60mm -- Clio
Car  Vectra
seen a few members on here are using Corsa B 60mm Springs...it drops the rear almost completely into arch, now not saying am going to buy them as am wanting my coilovers and alloys fitted first...but its an idea I have, now the alloys I will be getting like some of you may know are 16" Pro Race 1.2s with either a 45/50.
Would it be possible to have 16s with Corsa B 60mm Springs?
Camber needed?
Cheers for help
^^I was unsure if they would fit , but I got told off some lad who uses them on his clio and his is one of the lowest on here!
I dont even think I could use them tbh , Jimmy was on 15s I think and that was causing problems with arches/tyre wall , so 16s would just cause far to much hassle/damage haha taking the adjusters out with 16s will be safer for me
the springs will fit ok. can get some 90mm custom springs that would be the better option
^^yeah ben I seen a site that sells Clio 90mm springs was going to buy some tbh but a lad told me that standard coilovers offer 90mm so I was unsure?
springs will fit, their pig tale springs, exactly like the clio, they'll just have diffrent compression ratio the the clios equivalent.
