Couple more Questions and i will stop hasslin u all :)
  Black 182
On the Dash board where the clocks are, there is a light when i turn ignision on, its like 3 green lines with a stick pokin out the top. its goes straight off but i have no idea what its for, its on right hand side at bottom?????
Auto Wipers and lights, are there any way of controling them, as the neva seem to come on???
When i gave my car some the otherday, iam sure i seen a light flash up on right hand side, anyiedas what this could be??? was in very high revs, maybe limiter???
Think thats everything :)
  172 Cup
Auto lights you can turn them on by turning the Fogs on an off twice quickly, when all lights are off (i think) if not when the side lights are on. not sure about the wipers but i think you need to have i turned once for them to work with how much rain is falling.
someone correct me if im wrong.
Aint you got a manaul?
The Boosh!
ClioSport Admin
  Elise, Duster
  1. The light is an over revving light - basically means change gear.
  2. auto wipers need to be manually turned on by moving the wiperstalk down one nudge and leave it. if its raining it will do it its self. you can toggle the sensitiveness of it using the twisty bit on the wiperstalk
  3. auto lights - you quickly turn your headlights from 0-on about 3 times with the ignition in. you will hear 3 beeps. repeat to turn on/off.
  LY 200
When does the light kick in? I have never seen mine in 3 years so i take it, its been out for a fair old while! ;)
  Black 182
Did some chaved astra off the lights, and still gettin used to the car, its abit diffrent to change gears than my sister corsa 1.0 12v :)
  172 Cup
Was the Corsa an Automatic then?
I Change gear the same way in all manual cars i drive TBH, Dip the clutch select the next gear release the clutch hit the accelerator. lol
