Couple of Suspension Questions
  182, 172 Track Shed
Currently got a 182 with the cup suspension pack - am i right in thinking this means its stiffer AND slightly lower than the standard 182 setup? If so how much lower?
Im looking to drop it slightly and maybe firm it up a touch more with some new springs, around 35-40mm lower maybe
Im sure plenty of people have done this so if you got any pics around the 40mm mark that would be great, also is it worth doing from a handling point of view? Any noticeble improvement?
Joe
if you want a 40mm drop you probably want appex but apparantly they're quite harsh. I have Sportlines, they dont drop as much as they state but probably around 25 - 30 mm but they are the best springs bar none for the clio (prolines mite be best handling but only about 10mm drop - if that)
try a search on here for sportlines
