spanky2000
Clio 182
Hi. Was searching for torque settings in forums for this bolt as I am replacing all belts and pulleys. Seems its a certain torque then an angle. Also suggested is 120nm (I think!). I dont have an angle gauge so I tried the 120nm. After about 100nm I felt the dreaded this is getting looser feeling. Eventually it snapped but it tapped around and out with a screwdriver quite easily. Threads still appear ok and the old bolt fits in fine. Set the dephaser at 125nm and torque wrench seemed fine.
Long story short. Nerves are shot now between this and trying to tension cam belt and get cams to keep aligned (using Renault tools). Can I reuse to bolt even temporarily?
Thanks!!
Thanks!!
