Hi mate having same problem I'm going to replace spark plugs ht leads and coil pack. Came to change new crank sensor but what cable goes with which one? Pink and brown on new one and white and brown on old loom? And how did you bolt it on because it seems to me that the new sensor plug is in the way to folks back in the same position? Cheershad a go today at fiting the c s sensor and all went well . i had a few practice goes with my wire stripper before i did the cut as there is not a lot of wire on the loom side to play with. managed to do the soldering even tho you could probley get away with not doing that . all back together and it fired up . thanks for the help all ,,,,,,,,,,,,,
