Creaking when pulling away.
Car  2005 182 cliosport
Hi all
Got a simple one just need some confirmation.
I get a creaking from the o/s when I pull away and turn tight into a parking space. the MOT said the O/S track rod end had some play and needing changing in the new few months. Would this be causing the lovely creaking noise? if so how easy is it to do yourself or how much will it cost for a garage to do the work?
thanks in advance!
think i probably have the same issue, i blieve my wish bone needs replacing. one of the rubber joints has gone
i sprayed the joints with wd40 and it went away so pretty certain its my wish bone
its nothing major just an annoying noise. The car drives perfectly fine and the steering is still the same.
hopefully not a wishbone don't fancy changing one of those!
take the wheel off spray the wish bone joints with wd40 and see if it goes away
