Creaking Whilst Full Locked...
Car  R26
... but i have Solid Top Mounts fitted?? I was under the impression that they would cure the creaking but its still there? I there anything else it could be? Im on Sportline springs so i doubt its rubbing on the tyre?
Stuart, is the creaking coming from inside the car or definately from the top mounts/suspension?
The only reason I ask, over time (having had coilovers and solid top mounts fitted) because the setup is soooo tight, the steering column creaks. Simple spot of WD40 under the steering wheel/above the pedals helps enormously.
Worth a check, cured my noise :)
Cheers guys, its going into a Renault Specialist tomorrow, so ill mention what you guys have said and hopefully ill get it cured along with the 100's of other problems :(
