Cruise control not working after remap RS172
Car  220 Trophy, EVO 8
So If anyone is having similar problems... Cruise control doesn't work after I put the performance calibration from fastchip up.
If I install the stock .cal file, everything works fine. But when I install "_clio2_cb1n_6500_5404_WEB_RON98_0510" the cruise control on my RS 172 ph2 wont work in 4th and 5th gear. It will work normal in 1st, 2nd and 3rd, which is quite funny :D
I have already contacted fastchip and he said he'll look into it. I hope he really does?!
Anyway... Will keep this topic updated as soon as I get some new info.
When I remaped my 182 with a rstuner my cruise control worked but the display on the dash didnt, so I didnt know what speed it was set at. After turning the engine off and back on it then worked, sounds different to your problem though.
Henk from fastchip has been top notch when ever I have had to contact him, I have always had a straight answer within hours, so I'm sure he will sort it
Mine stopped working after I put the map on my car. Although after a couple of drives it worked perfectly again.
It needs so many miles to re calibrate or something so should kick back in soon enough
Send Henk an e-mail, he sorted me out, this happened to my 182 and 172 when remapped, he fixed it both times.
