Cup 172 lightened flywheel
Car  Cup Turbo, Flamer
I've had a search and it's a mix bag of responses!
I've got the box and clutch out anyway for a rebuild, so it's no extra hassle to change it.
So......are they worth it?
Have seen this done on other cars, makes the engine really snappy, pick up was ace :D .. only down fall was cruising, just didnt seem to have the same holding power at 70+, assume its to do with the momentum it can hold with the standard fly wheel.. google it & there is loads of info on the subject
If the cars in bits & you can get it cheap enough & are more of a round town/track driver then go for it, you'll also make your cup even lighter :D
James
Cheers dude, only driven to/from track, so not really fussed how it is under normal driving!
Any other opinions..?
You not got yours up & running yet John!!???
Mine started today for the first time in 6months!!!
Had one on the punto, was shocking at pulling up hills. And if they are to light can have an effect on the reason for the flywheel being there. So aslong as its not to lighweight they are good.
And as said, while changing down gear it dropped its revs super fast, aswell as pickup.
Not yet Lee!!! Had all sorts happening!
Got the box out now...check my progress thread for pics and shizzle!
You got bodies and the like now?
Cheers for the mate, i'll prob not bother to be honest, as you've confirmed what others have said!
