I have been running the cup alternator set-up on my PH-1 for 2000miles without any problems at all...
Over the past couple of weeks a squealing sounds has developed from this area, which is getting progressively worse!
The noise is alot worse when the engine is cold, but still slightly noticeable when warm.
Do any of the pulleys have bearings?
Are there any "common" parts that can fail (apart from the belt
I am going to try running a belt with less ribs on too see if this cures the problem, as the belt runs VERY close to the cambelt cover (is this normal?)
Any help mucho appreciated
