Quote: Originally posted by Loony on 25 June 2005Quote: Originally posted by Neil82cup on 25 June 2005Quote: Originally posted by Loony on 25 June 2005Quote: Originally posted by Neil82cup on 25 June 2005will get fronts done during week when I can get it up on a ramp. IIRC you can pop the plastic covers off the sides of the seats and unbolt the runners from the seat. Saves pissing about under the car. I had no choice as i was fitting buckets. Cheers L, does anyone know if this is right?
just had a look at mine without taking the cover off (couldnt be arsed to go to the garage and get the tools out) and it looks like the rails/subframe have studs on them and the seat drops down and is held on by nuts. Only other thing is the seat tilt/release cable is clipped in but from what i can see its that straight forward. Now go fit the fronts b**ch, lol
Had a look at it and it seems easy to unbolt them from runners until you look at the bolts on the side next to the hand brake.One of the bolts is under the seat belt prentensioner, is it ok to just unplug the wire going into the prentensioner?
[Edited by Neil82cup on 6/25/2005 3:29:10 PM]
