Cutting a bumper
need to re-cut the hole for the prospeed in a new bumper, how should i go about this?
i have a made a template so the cut is in the correct place, but whats the best way?
cheers
FTW
i can get one, would that be the best bet?
when i was at prospeed, they held the surround over the bumper, drew round the inside of it, then cut that with a little electric cutter.........then used a dremmel i think to smooth the edges and make it a bit wider until the surround was a perfect fit........ no idea what the cutter was though!
  www.renparts.co.uk
yeh mark it out. cut as roughly as you like as long as you don't get to the line then file it smooth with the dremmel up to the line.
