cv boot won't marry up up to gearbox flange?
Just looking closer at some pictures of one of my old genuine shafts that s**t itself...
It seems Renault just used a boot with a flat section to overcome the problem anyway?!
Compared to the J&R shaft with a traditional type boot causing the issue...
^^ Not my photo
There isn't much in the gap...
@bloke there is no real way to swap the boot is there? Perhaps sending the shaft to the people who recondition them to fit the correct boot and it's still a money saver over Renault ones
Fair enough, was only responding to your questions/long post.
We only had a real answer about these shafts on the N/S from imprezaworks car, no evidence of the drivers side one that I could find since an apparent design change. It was a gamble, but back to square one, unless you get hold of the correct CV Boot and job done for cheap.
Cannot find anyone other than Renault that sell new O/S shafts for the Cup
Shaftec have 172 cup available R209AL left 657mm long & R209AR right 740mm long,with no support bearing.
Same as some scenic & megannes.
I paid £72 ic VAT for my RH PH (R518AR) at my local branch of Andrew Page.The one`s on eBay are priced a bit more than that..
I have had it a year,10K miles with no problems.
With reference to copper based grease.It should not be used on any moving parts at all as it is abrasive.
It is to stop bolts,nuts,spacers & motorcycle wheel spindles etc from seizing up with corrosion & is highly effective.
It`s shame J&R have not addressed this gaitor problem.I assume someone has told them about it.
that's single piece shaft so no issue with it catching on the lug on the block.
Or a quick measure up and I'm sure we can find an alternative option.
http://www.race-tec.com/drive_shaft_cv_boots.html
have fitted inner boot but can't for the life of me remember the make?? probably gkn or lucas? will see if i can find out tomorrow.
that's passengers side inner boot.
Sorry,my error.Thanks for pointing that out,I was rushing it.
You are correct the one piece 172 cup shafts DS20/21 will not suffer from snagging the block.
To honest,if anyone needs a non cup ph2 RH shaft,just pay the £72 for a shaftec R218AR rather than messing around trying to correct the J&R shaft.
J&R would seem to have tens of thousands of satisfied customers,but have a problem with this specific shaft.
http://www.ebay.co.uk/itm/NEW-BORG-...991883?hash=item5b1deb6c4b:g:wSIAAOSwhkRWcdnz
could offer a solution if you already have a J&R shaft with a damaged rh inner boot,but otherwise sound.
Just in case anyone read through this.
DO NOT APPLY TO MOVING PARTS.
