Cylinder order
Car  Mk3 clio 1.2 turbo
Been looking all over to try and find what order the cylinder are numbered and had no luck, if anyone could help that would be appreciated and any tips on how to change an injector thanks.
Any good?
The cylinder ordering is in the above post. As for removing the injector and rail it's pretty easy. 3 bolts (one removes the fixing for all the wiring. Take that off to remove the fuel line more easily.) When you put them back in, make sure you use some sort of lubrication. I use WD40 on my fingers and then lightly lubricate the O rings. Helps massively when putting them back on
