D4f torque settings
Not 100% sure of the bit you mean. So just taken from Haynes manual hopefully it helps.
Camshaft
Stage 1 - sprocket end bearing cap bolts 1 & 2 = 9nm
Stage 2 - rocker arm rail bolts = 5nm
Stage 3 - bolt 3 fully loosen then tighten to 7nm
Stage 4 - bolt 3 angle tighten by a further 50 degrees +/- 6 degrees
Stage 5 - bolts 4 to 12 repeat stages 3 and 4 in turn in the correct order
