dash light problem
I cant get the lights for illuminating my dials to work. I have tried all my fuses and changed the bulbs.
Any ideas on how to fix it as its hard seeing how fast your going at night :cry:
i have the same problem every now and again but mine cuts the Dials as well so they dont even move. but then i bang the dash and they come back on. i think mines a loose wire behind the dash tho i just cant get behind the clocks to look. well cant find how to get behind the dash to look
i have tried the dimmer switch, took the wires out and bypassed the dimmer switch but still no luck.
craig taking the dash off is really simple, 3 t-20 screws on top of the dash on the heater vents and 2 on the side of the dash when you open the doors. The top just pulls off and you can see the clocks exposed. Undo the 2 screws on the top of the clocks and there is 2 others below that you need to get at from underneath. It sounds daunting but its really simple, the hardest thing i found was gettin the spedo cable from the back of the clocks. To do this you just squeeze the white round plug and it should pull off.
Hope that helps craig
cheers ill ave alook at that when i get some spare time Dont know why my fonts gone like this btw didnt even change it jsut the works computers.
[/QUOTE]
my dash-lights used to go out like that on my previous car (97 1.4rt) - i just tapped the dials with my fingers - magic :)
