dCI service
Car  Clio Dynamique S DCI 86
Okay, I'm servicing my MK3 dCI tomorrow, its on 48,000, so I'm changing the oil, fuel, air and cabin filters, also oil change, checking lights tires belts and seatbelts etc.
Does the front engine under tray remove easily..a bolt or something? And what type of fitting is the sump drain plug, I heard on the MK2 it was a 8mm hex, is this the same?
I have a new washer to replace the old copper one but can i reuse the bolt?
Thanks Very Much
Adam
Thanks very much, so undertray is easy just a ball ache, and got an 8mm square so its all good.
