Wow this threads turned into a hot one lol!
I thought I would give a quick in sight information on the results we found when we were testing a de-cat on a 182 at Torque of the devil last year (dyno dynamics rr)... Sadly I have no graphs of this as there were all stored on my previous work partners lap top so its your call on if you decide to believe my findings or not, frankly couldn't care either way
Test 1. Completely standard 182 bar milltek cat-back, Rolling road showed normal power/ torque, was in the region of 170/173 bhp
Test 2. Same car but this time with the decat fitted, Peak power was near identical but lost a good chunk of torque at around 3,000rpm (this being the flat spot your feeling in the above threads) AFR in the mid-range ran very lean hence theloss
Test 3. Decat & ECU calibration (not a live, Just our generic) good solid torque curve with gains of over 10ftb's points below 5,000rpm and no flat spots at all! only showed a rise of a couple of peak bhp but it was still on standard airbox/inlets etc
Test 4. removed the de-cat and re-fitted the catalyst, and left the ECU calibration on, torque at 3,000rpm was lower than test 3, in the mid-range test 3 & 4 showed near identical power, Up top test 3 held the power much better
Now these test were carried out over a course of 2 days (due to fitting/ removal of parts) so there are variations there that couldn't be helped, but the best figure of the test was test 3.
Moral of the story is, If you wan't a de-cat, get it mapped and you should see gains, if you don't get a decent calibration your just gaining noise!
James
Wise words.
