Decat Question
  Cammed 182 :)
Having just ordered my RS192 decat exhaust sytem what will happen with the lamda sensor when put into the decat pipe? I take it engine management light will come on and will it run lean? Is there a souloution to this Cheers J.
  Mk5 golf gti
mine didnt come on at all when i fitted mine to the 172
plus i hink you can switch it off with a simple code reader if i does come on
id recomend a remap with it
if you have the pennies :D
The Boosh!
ClioSport Admin
  Elise, Duster
It varys mate. Sometimes it comes on sometimes it doesn't. Either way there is an ecu fix for it IIRC.
  Cammed 182 :)
Yeah getting my matched inlets put on, exhaust, viper with CAF and then remap :)
If the light does come on will it run properly?
It'll run fine but most likely throw up a CEL due to a CAT Efficiency error, typically the rear probe is a monitoring probe for the CAT.
