Decat questions
Car  Polo GTi
Right, was gonna keep the Cup standard but the shitty Kit Kat Cat is rattleing like a b*****d and its annoying me.
2 Options go for a decat, risk the management light coming on the dash or get a new cat $$$
If I go decat, and I connect the first Lambda will it be OK or is it a hit and miss affair as a search would seem?
If it does come on would one of these things get rid? http://www.k-tecracing.com/show_product.asp?id=2400
light makes no differenc to the car's running if its on or off
those reader can be had off ebay for £20
are you sure its not the centre section?
Na Jordy replaced the centre section a few months back, I took it back cause it was rattleing, the big man said it was the cat.
Yeah the light makes no difference, but it would f**k me off seeing it everyday, so one of those readers would clear it off?
Tempted to get a full exhaust but I wanna keep it standard, would rather spend my money on mods to the Williams.
If I remeber correctly Jordy just whacked some pipe on Chris n Nics car and I dont think he has ever had a warning light?
even if you turn the light off, it'll come back on again
best bet is to pull the clocks out and slide a bit of tape behind the light mask
haha creative thinking I like it!
Why are the Mk2s so gay :S
There must be some sort of reason why the light comes on with some cars and not others, piece of french crap
or just remove the l.e.d from the circuit ive removed loads
steering
abs
serv
exhaust
doors open
thats all i can remember lol
mine was lit up like an xmas tree
Yep mine has never had any warning lights...piece of straight pipe welded inplace of the cat with the lamdas on either side still attached
Chris
Mine was fine (still is) after 2.5 yrs decatted. Leave the 1st one in, then plug the second hole (mate managed to source a plug from a motor factors :)), then leave the 2nd probe connected to the loom. Tape it up and tie it up somewere. Try that first, worked for me!!!
or you could just take the l.e.d off the unit takes about 30 mins, what theirs around 12 little screws holding dash in then it pops out do clocks then reverse simple really
