Dephaser oil supply
  172 cup, Impreza P1
If the dephaser solenoid is disconnected, is there any oil still supplied to the dephaser?
I plan to remove the dephaser but don't want oil leakingalong the camshaft to the pulley.
​Cheers
  172 cup, Impreza P1
Can you use this kit on standard 1*2 cams with no other mods?
Is it just the 1 cam seal I need then?
I was thinking about turning the length of the inlet cam to the same length as the exhaust cam and then welding up the 3 oil ways on the inlet cam to stop any oil coming through.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
I need to ask, why? Surely all the effort will be worth nothing on standard profile?
  DON'T SEND ME PM'S!!
if you want to run non-VVT, you need a non-VVT inlet cam. I've no idea why you'd want to do it though, it's so easy to control switching it at the right point, there's nothing but down-sides to removing it.
  PH1 loads of boost!
No you don't.
Cupman there is information elsewhere to tell you what a lot of others with F4RT have done ;)
