Distribution Blocks
MK3
Car  Dynamiqueee
I currently have 2awg power cable running from the battery to the amp. I've got another amp for the comps, just need to find a distribution block. All i can find, are ones with 0awg or 4 awg input.
I've seen this :
http://www.caraudiodirect.co.uk/phonocar-2awg-power-cable-adaptor.html
But doesn't it kind of defeat the whole object of using thicker cable? Also a silly question, but if a distribution block it has 1 input and 5 outputs, would just having 2 outputs be a problem? Can't see why it would but thought i'd check. Thanks
In simple terms;
Larger cable cross sectional areas have lower resistance....
Shorter cable runs also have lower resistance....
So, longer cable runs require higher cross sectional area to keep resistance to a minimum....
So, shorter cable runs require lower cross sectional area to keep resistance to a minimum....
Larger power draws require higher cable cross sectional area to keep resistance induced voltage drop to a minimum....
Longer cable lengths require larger cable cross sectional area to keep resistance induced voltage drop to a minimum....
So;
Longer Cable Length = Higher resistance
Higher Resistance = Voltage Drop
Voltage Drop = Lost Performance
Go for a '0awg' to 2X '4awg' fused dizzy block....
