For the hassle.. just buy a proper hose, or buy a hose joiner where you drill a hole in the hose itself and insert the nipple and use a nut to secure it on the inside
Like this?Catch tanks are easy! Fit your DIY induction kit (I'm contemplating one, routing it down to behind the front N/S wheel!) and then run a hose from the rocker cover oil breather nipple to the catch can, and then fit the oil breather filter to the other catch can hole! See my paint diagram!
Oil Breathers fitted to the rocker cover clog up with crap and go all horrible! Catch Cans means you can empty that crap out!
Jack
Heres mine Danny bracket from solid piece of ali
Cheers Pat![]()
Cheers Pat![]()
Looks great. Maybe pat could make a couple more?
Not an oil breather which seems to be a 5 second job?
Hose joiner is a 5 second job.. cheaper than buying filters/catch cans/additional hoses IMO
Just all seems a bit pikey and trying to save pennys when another £40 or so could get you a samco that would save all the hassle over an oil breather pipe problem
Whole idea is to get rid of the oil returning back into the inlet which in turn makes performance worse.
I hear what your saying but honestly chasing performance on these cars is a complete waste of money IMO
