e92 + E46 M3 + Cup
So still trying to get a little bit more out of my 172 & the plan was to send the inlets off to Angle works/GDI but the turn around time is just not going to work for me as i need the car during the week plus doing this my self would be helpfull £££ wise
So basically here goes, i use my dremel alot, has been a great investment & use it enough to be very confident with it, i have done engine work before with it, only thing being it was on a 1/10 scale r/c car, but the theroy is the same lol! so my plan was to remove the manifold & use the gasket as a template, remove the gasket & carefully remove the excess ali, then move onto smoothing it into the channels then finnish off with some 800/1200 grit wet & dry to give a smooth finish but still avoiding the polished finished wich from reading on line is the worst thing you can do.. now obviously i dont expect it to have the same results as Angel works/GDI as i'm sure they have spent alot of time & effort getting the inlets as they should be but in theory providing i dont go past my markings & make it as smooth as possible air flow i should see gains right?
If any one has any input, ideas, pictures that would be ace
James
James
