Do harnesses reach back to the rear upper seatbelt mounting points?
Yep mine reach. Got Sparco 3 points and there's plenty of adjustment left. Mounting point is a good height, just above shoulder height, very slightly offset to the outside of the car but seems a good position.
they should be mounted to where the rear seat belts bolt to the car.
Mark, get a bar welded in across the rear suspension turrets and mount them there.
Harnesses look rediculous in the upper seatbelt position.
Get the rest of the cage done whilst you're at it! ;)
Any metal worker will be able to weld a cage in properly, fmp will know someone.
They might be technically better at the top seatbelt mount but they look crap! As Jon said i'd get a bar welded in, any metal fabricator will be able to do it!
