Do i need this block?
  Hondata'd EP3 Type R
Hi, Im in the process of putting a posh battery terminal on my yellow top, to match the negative, However, I'm having trouble with the starter motor/alternator wiring.
AS you can see in the red square on this pic there is a plastic block, Do i need this, Or can i chop it off before here and just put the wires into my terminal?
Bluebeard
  Whichever has fuel
On a car i recently sold, i chopped it off and it was fine.
However, this was the day before the guy collected it, so I couldn't tell you if it lasted/didn't blow anything up.
Seemed fine at the time tbh.
  Polo + Micra
i think it should be fine to remove
(also you know your supposed to take the handle off the battery)
