Do induction kits damage your engine?
  Clio 1.2 16v
My local garage advised me to remove my air filter as it damages the engine, is this true? cuz i really cant see how?
  Clio 1.2 16v
well my car runs fine with it on, why would he say it damages engines? oh n also he said it was a stupid boy racer thing butr they dont relise what its doing to thier engines.
  Motorbikes
Sounds ghey to me. I had a K&N on my 1.2 16v for about 9 months or so and it ran fine.
If they're were any concerns, why would people buy them?
  VW ID.3
How can it hurt an engine, just lets it breath a bit better! was it a renault garage who told you this?
  Tangoed Works
The guy was prob old skool. Its a know fact that these open IK can let microscopic particles through and over the years do make the engine wear that little bit faster.
Hence why manufacturers use paper(and because its cheaper). It might block that little bit of extra air, but they would rather have that, then engines wearing out slightly faster.
Ali
  V6, Trackhawk, GTS
I had one where the wire besh broke up and ended up in the plenium chamber! Fuckin lucky it never went into the engine!
  RenaultSport clio 172 mk2
The local garage isn't wrong. But he's overstating the case.
If you lived in an area where there was a lot of blown sand or grit that was picked up and sucked into the engine a sports filter isn't going to do as good a job as a standard filter. A dry foam filter is good enough for a racing engine's short life. An oiled foam one has to cleaned and re-oiled periodically, and very few people do.
Do you live in an area, or drive on the sort of roads, where a lot of sand or grit would be being sucked into the engine?
  Ph1
Well he lives in Leicestershire not Iraq
As long as the filter isnt damaged it'll be fine.
Years back a AA man told me chipping a car damages it because it creates heat. He then nearly blew my ecu up with his fantastic knowledge by by-passing something in the engine according to the Ford dealers of the time. 'Computer mechanics' know nothing
  Shed.
i had one on mine for about 2 months, i ended up taking it off because it sounded gey when i was only actualkly doing like 20mph.
