iv been i need spacers and longer bolts due to the offset on valver wheels being et 36 and the offset on trophy wheels being et 45 thats a 9mm difference. as was told they would rub if i did not get spacers and longer bolts??
yeah i know it does but thats what i got told i need to do cos of the offset being different. the trophy wheels are will rub on the inside of the wheel. i think this was due to the trophy having a wider track than the 172 normal turinis are 37 i believe and fit the valver no probs. but the trophy wheel is et45 and the wheel has to be spaced with a 9mm spacer to reduce the offset to 36 which will be fine.
