Does my 182 have an alarm?
Open the door with the key . I think that should set it off if it has .
Just checked
I have a red flashing light by the speedo
I've just locked it with the fob, then opened the car with the key, nothing went off.
Should it have a alarm standard on the 182?
As above you should have the alarm sensors on the a pillars and another led on the dash ( not the flashing immobiliser light )
Definitely don't have sensors on the A pillars :/
Did all 182's come with an alarm? Has mine been removed or wasn't it spec when it was built
No sensors suggests it doesn't.. Any etchings on the windows ?! Is there a siren under the bonnet ?
Not all RS's had alarms.. the import's didn't AFAIK.... My old Ph2 didn't. Grateful TBH - something less to go wrong !
Just checked
The red flashing light next to the speedo shows the immobiliser is set .
How can I find out if mine is an import then?
Is it bad it might be an import?
Answer questions:
It shouldn't make a blind bit of difference.
Didn't they stop etching the windows on the later 182's anyway ? Nothing wrong with having an import mate . Its exactly the same car as the so called UK models , it was made in the same factory . The only difference is they didn't come etched windows as already said , no alarm which was fitted in the UK at the import centre which by the way only had an 18 month warranty on them and often went wrong and no locking wheel nuts which can be bought for a few quid anyway . I'm on my second import and contrary to popular belief is worth just as much as a UK model when you come to sell it . Enjoy your car , get an alarm fitted . I have a Toad A850T which intergrates with the immobiliser so you just use the standard key to set it .
I dont have an alarm or locking wheel nuts so looks like its an import.
I still don't know what this window etching is all about
It's some sort of security number they etch on all the windows . I wouldn't worry about it . I'm surprised you got insured as most insurance companies i contacted wanted at least a Cat 2 alarm fitted . When i got mine fitted i got a £60 refund off Adrain Flux :D
mine puts windows up if i leave them down after locking with fob. Also if i unlock car with fob and dont open a door within 30 sec it locks itself again is this after market alarm or standard i have sensors on pillars and a red light just above heater controls?
thanks Dave
