Does this have cup packs
  Clio MK 4
as above.
Marky_
Assuming the wheels came with it, then it has suspension cup pack. No spoiler pack though.
  Clio MK 4
if you look at the last picture the back wheel looks like its flaked. Does this mean it could have been sprayed? as i assume original ones wouldnt flake?
Rob
TBH, I'd say you assume wrong, Renualt paint isn't exactly known for its durability.
There is an easy way to check for sure, whip a wheel off, and measure the bolt spacing on the suspension IIRC, cup packs are different to normal.
  Clio MK 4
ye it just 3 hours away so bit of a pain to go check it. The advert does say cup suspension pack both. Would refurbing it the same colour be easy
Rob
If its standard you could probably just pick up a spare cheap enough on here. If not most good wheel places would match it up as best as possible for around £50
DrR
  VW Golf GTD
If you going to look at that, it's had a new bumper/respray.
  Clio MK 4
do you think it a good deal? 54 reg, 36k miles belts done january, hpi clear, braided brake hoses mOT due feb 2011, tax aug 2010 costing 5.3k
